I know little about tractors other than a video my husband made for me before he died 5 yrs ago explaining how to start and drive it and very basic maintenance. I have used it probably 7 to 10 times for mowing until last fall when one of the blades got wedged under the other.
I suspect the mower is larger than it should be for the B7100. My reasoning is that my husband ran water in the tires (since replaced) and had installed weight on the front bumper. Also, whenever I tried to start the mower, it seemed to really want to stall. However it did run it fine once it got going so maybe that was something I was doing wrong.
My questions are:
1. How do I know if the mower is oversized? It is 5 ft wide and pictured below. I do have the manual that says max width rear is 48", max width mid is 60" and max weight 300 lbs. Is "mid" talking about a belly mower?
2. If it is not oversized, then what is a reasonable fee for me to pay someone to fix it?
3. If it IS oversized, I want to buy a new one. Is Rotary Cutter the correct name for this mower? What do I need to know when shopping for one? Doesn't seem like a complicated piece of machinery so is there much difference between different brands?
Thank you!
My questions are:
Thank you!
