Why run high rpm's with a diesel ?
dochsml
L4701HST
Jan 21, 2020
216
20
Leonard, TX, USA
I understand that concept... What I’m wondering is how “balls to the wall” came to be thought of as anything other than a ball-shaped throttle and a firewall. I don’t see a connection to a governors ball-shaped weights and a “wall”.
I don’t know. I said balls out not balls to the wall. If I had to guess though, just as balls out can now refer to gas and Diesel engines, I’m sure balls to the wall can also refer to more than planes. I’m sure if we had some steam engine purists on here, they’d want to chastise for me saying I was running my diesel balls out. Maybe there should be some nuance between the two terms? Balls out just means full throttle or full speed and balls to the wall means in attack mode or on a mission (but also at full throttle)?
4,266
It’s called a flyball governor. From James Watt I believe. Modern etymology expands the term balls out for pretty much anything with a throttle.
Back to the OT, ... I think high RPM is considered to equate to high wear rates by most people...and that is not a linear relationship. The number of revolutions an engine accumulates is not a finite number as it relates to longevity. Once the high-wear initial start-up/warm-up occurs... very little additional wear happens relatively speaking. The lubricating oil insulates the moving parts from each other and carries away heat.
The highest wear occurs when RPM is varied repeatedly. If the engine is stabilized at RPM and temperature it suffers very little degradation as long as oil pressure and temp remains stable.
High RPM also does not equate to high piston/ring wear. High LOAD does, however. Example: If the engine is operated at less than optimum RPM and increased workload is applied, the engine initial response is slowing... which changes the oil-film-surface-tension and can cause momentary increased wear on the rotating parts... THEN the governor (in an attempt to restore selected RPM) will increase fuel-flow, which FURTHER loads the bearings.... AND the manifold pressure is increased as the throttle is opened further loading all moving parts...(the piston rings are expanded against the cylinder walls at this last point thereby increasing friction, just when RPM lagged and reduced the “oil-sling” lubrication of those cylinder-walls which normally lubricate and cool piston rings and pistons.)
The comparative result is that high operating RPMs can actually REDUCE engine wear compared to lower RPMs that create demands for increased power due to changing loads (such as acceleration requests or HST forward/backward requests or clutching requests.)
Another illustration is the well-known longevity of stationary engines which operate for long periods at stabilized loads and RPMs. Those engines avoid those increased-wear situations just-described and therefore have long lives. Engines upon which frequent RPM-changes are demanded have noticeably shorter lives.
Bottom line: If your operations require frequent throttle or governor actuation then a higher “base” RPM of operations will likely reduce engine wear AND fuel consumption and result in longer engine life.
SDT
Apr 15, 2018
3,709
1,431
How is a speed-governor related to a “wall” of any kind? ...and especially since most counterweights are NOT ball-shaped?
Both "balls out" and "balls to the wall" were terms used by operators of stationary reciprocating steam engines long before "balls to the wall" was adopted by those in aviation.
Reciprocating stationary steam engines were usually situated in an engine house. Usually, the flyball governor was situated to one side of the engine near the wall of the engine house. When operating at full speed, the governor balls were fully out or nearest to the wall.
SDT
4,266
SDT
That is quite an imaginative answer. In enclosed spaces such as engine houses the engines were not situated next to walls... but were in the middle of the room so that easy access was available for maintenance/servicing as well as air circulation.
Try another.
4,266
SDT
Here’s an illustration that shows the governor and its balls were near the center of the operating machinery and no where near the wall.
dochsml
L4701HST
Jan 21, 2020
216
20
Leonard, TX, USA
I agree, we are getting WOT (way off topic). I’m not a mechanic, but I know enough from my toys and time to be dangerous. I mostly agree with everything you said, but it ignores heat. It can break the oil down and cause wear.
SDT
Apr 15, 2018
3,709
1,431
You should believe whatever you choose to believe, George, and I will believe what my experience has taught me. I do not give a RA.
SDT
4,266
That’s why we should use high-quality oils (not El-Cheapo brand).
And I did not ignore heat, I specifically addressed it.
4,266
SDT
I believe you do. Show us an example of what you believe so I can be better educated. I’m not after “winning” I”m looking for truthful answers.
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
I just asked my grandfather where the term came from and he said steam engines before I finished the question. He also mentioned "balls out".
I believe he actually ran some of them so I will take his word for it.
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
So it took a while to get the story out of him.
He said the walls had nothing to do with traditional walls. The balls, when spun would wind out until hitting the stops on the flanges. He said the stops were called the wall on the flange.
He said "balls out" would occur at almost any speed so the saying was refined to balls to the wall, meaning the physical maximum it could go.
4,266
SDT... You win!
After further research I found another photograph which I felt CERTAIN would end this in my favor... (see the pic below of an entire ROOM of engines, NONE of which are anywhere near a wall.... but instead installed in the center of the room JUST LIKE I SAID....)
However, actually READING THE TEXT associated with that photograph, I found the following:
“ Quimby, a floor hand who removed blemishes from finished steel from 1974 to 1988, also shared the origin of a common saying: balls to the wall. Pointing to the spinning flyball governor atop the Corliss engine, he noted that when the machine is going full bore, centrifugal force pushes the flyballs outward, toward the walls.”
I’ll never question SDT again. ;)
PapaJ
L2501 HST
Apr 28, 2020
284
107
TX
Both can be hard on your back.
They definitely are, that's why I bought a Kubota BX2680 shovel. I have a lot of disabilities from 25 years in the military, and my back is one of them. Bending over to tie my shoes is painful. Life continues...
Dunbar
L2501 LA525 QA PFL2042 Forks RCR1860 FDR1672 BB1560 EA55 WR Grapple FitRite TnT
Aug 2, 2018
217
11
NH must have lots of old engines and operators. I have a friend who is a gas compressor mechanic and he was called from Colorado to NH to work on an engine that had a brick crankcase and leather bushings.
The flange stop as the wall makes sense as the term would work if the engine was located outside.
greenacresnorth
L2501,BH77
Feb 18, 2018
175
29
Morganton,NC
AKA balls to the wall.
SDT
Ball to the Wall is actually different but the same to Balls out. "balls out" is a reference to steam and hit and miss engine governors, "Balls to the Wall" is a reference to WW2 aircraft throttles and prop control levers, with all throttles and prop control handles full forward, engines are making max RPMs and manifold pressures, hence balls to the (fire)wall.
greenacresnorth
L2501,BH77
Feb 18, 2018
175
29
Morganton,NC
And in locomotives where my grandfathers experience was.
with diesel and electric Locos full throttle is referred to as "notch 8" and on some EMD and old Fairbanks Morris engines you could push lever past notch 8 for a extra 10 RPMS, also know at "notch 9" or "stop Notch"
on ships engine power is rated at bells, on the Coast Guard ships I was on, we had diesel bells and bird bells (turbines), answering a flank bell on the diesels would yield 16-17 knots, on the birds a flank bell was around 35-38 knots. we also had a war emergency flank where we bumped the N-1 speed of the turbines up and injected water, we could pick up another few knots (classified) to catch a go fast. when all the crap would start shaking off book shelves we knew the Capt aksed for WEF, affectionately know as When Everything Flys apart.
