B7100 HST Hydrostat/Charge pump.
Mogs84
B7100 HST
Jul 23, 2019
31
Wales -UK
Hi all,
If anyone is interested have a search for my other posts, but I've got a HST issue whereby it just stops functioning altogether, mainly at high rpm and then it needs to either have the revs dropped or wait until it decides it'll work again.
Anyway.......
what has everyone else done when the hydrostat or charge pump has gone bad on these?
I'm UK based and parts just don't exist.
Does anyone know what other machines share the same part/parts etc?
Thanks.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Air could also be caused by a leak at the large suction rubber hose near the hydraulic pump, or cavitation caused by a blocked suction screen.
Mogs84
B7100 HST
Jul 23, 2019
31
Wales -UK
All oils and filters are new, genuine Kubota items.
All pipes have been replaced, all suction screens cleaned.
Oil level is correct, even tried it higher than the correct level to see.
Oil isn't foaming, but it being churned around quite a lot.
Previous owners have clearly used ATF fluid instead of the correct fluids.
So either charge pump or whole HST unit will have issues.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
off topic.... you have an 84 Mog? hmm. 416?
