Have a 2WD L245 that has served me well for 4+ years, used mostly exclusively for mowing. I was thinking of getting a 3pt bale spear (probably the type that slide under the bales rather than stab them) for the rear, but wondering if the tractor could lift them? I wouldn't be trying to load them into/on anything, just picking them up off the ground enough to move them into a pasture. I do have 4 55lb suitcase wights on the front.
I've seen as high as 1,540lbs at the arms (on TractorData) but I've also seen it listed as 1,100 at the arms, and implement max weight ratings of 600lbs. I've got the same .pdf Owner's Manual that's been floating around, but I don't see lift or implement capacities in it anywhere.
TIA.
TIA.
