Backhoe for B2320 - Is Kubota BH65 still available?
PWarton
17
New Mexico
I have a B2320. I would like to get a backhoe for it. Years ago, I saw the Kubota BH65, but every time when I search for BH65 the Woods backhoe shows up.
Is it save to assume Kubota is no longer manufacturing their backhoe for this tractor?
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
304
257
catlettsburg, ky
Well, if you go to Kubota.com and build a B2320, the bh65 backhoe is listed as an option.
6,119
The real issue is not the BH but the subframe to mount it to. ;)
beckmurph
Aug 23, 2012
304
257
catlettsburg, ky
Looks like the subframe is $998 in the quote on build you Kubota.
So everything should be available.
PWarton
17
New Mexico
Thanks for that info. Every time I Googled BH65 the Woods model showed up. I guess Woods renamed there hoe to BH65 too. Confusing.
Anyways, as far as the subframe, I use the MMM a lot. Will the subframe interfere with that?
beckmurph
Aug 23, 2012
304
257
catlettsburg, ky
No.
I had a mmm and bh65 on the 2620 I owned several years ago.
PWarton
17
New Mexico
About how much is the BH65 backhoe? I'm guessing $7K when all is said and done? does that sound about right? Also how powerful is it? Is it good enough for a basic homeowner to use? Also, how does one go about purchasing it, do I call the local dealer? Is it something they ship or I go to the dealer with a pickup truck or trailer bring it home install it myself?
Thanks everyone for your help.
KTuk4J
B2650 Duetz Allis 6275 CAT D6 CAT 110B
Mar 2, 2020
106
NW OR
I'm sure they will install it for you, I would estimate $500-$800 labor.
Or you can do an out the door purchase from the dealer where you install.
Don't think Kubota will drop ship at your location.
If you have multiple dealers around I would try to negotiate the best price.
I'm about to purchase and BH77 for my B2650 and I've been quoted as much as a $800 difference. Now you as well need to decide if you want a thumb (if offerred) which I would definitely recommend as well as the right size bucket that will meet your needs.
PWarton
17
New Mexico
Thanks,
Yes, definitely will purchase the thumb.
Will the BH77 fit the B2320?
beckmurph
Aug 23, 2012
304
257
catlettsburg, ky
The bh65 will only fit the b2320.
The attached screen shot shows price of backhoe, subframe, 16” bucket, and manual thumb.
The bh65 is a straight boom design.
It is a fairly stout backhoe.
If you bought your 2320 new from a dealer, you maybe able to work out a lower price than what is listed in the above quote.
Soso
B2320
Jan 8, 2017
Kirkland lake on Canada
It works great,I installed the 4 point hitch myself in about 1 and 1/2 hours.
Took a bit of time to backup to the hoe and figure out how to pin it up for the first time but it is not bad to do.
The new seat base did not line up with the new brackets so I drilled the bars to mount the new base.
