Reinstalling blades after sharpening 60MMM
Captaincj
Hugo, MN
Question, just sharpened the blades for the first time on new BX2380, and after reinstalling the blades on 60MMM is there an optimal/preferred/best VooDoo way to align the blades directionally relative to each other? In other words, all blades at 12/6 o'clock? Outers at 12/6 o'clock, inner at 3/9 o'clock? All different? Doesn't matter?
Thanks to all.
BigG
Sep 14, 2018
1,953
774
West Central,FL
There is no need to worry. They can not hit each other.
4,185
It does not matter.
5,255
1,057
There is a caution in the Kubota installation manual I have .
The blades should be positioned as far from each other in order to prolong the life of the blades.
See attached from the manual.
My sense is that the concern is for a blade blasting stuff against the turned up back side of the blade in its discharge path
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
I alternate my blades by 90 degrees after sharpening, but they will end up random in short order. If you cut a LOT of grass, the blade on the discharge side should be relocated to the inside spindle to even out wear. I cut about 25 acres per week and can tell the difference in blade wear, but not much.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Seeing that diagram really surprises me. Unless the blades are chain driven, they would never stay that way.
SDT
Apr 15, 2018
3,676
1,403
Bingo.
I rotate my blades one position each season upon sharpening.
SDT
SDT
Apr 15, 2018
3,676
1,403
SDT, you can make an entire season without resharpening?
Yes.
I sharpen each fall upon removal and servicing of the MMM. I usually sharpen with a file but doing so goes through a good 14" File to sharpen all three blades.
I rarely hit anything other than grass when mowing.
SDT
3,650
2,071
Actually, that picture is showing to rotate the blades after sharpening.
The left blade is moved to the center, the center blade is moved to the right, the right blade is moved to the left.
The clocking of the blades makes no difference as the will slip in the belt or on the spindle a little over time anyway.
Just make sure they are not downside up! We see that several times a season.
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
Well dang! I can see that now, but having seen that diagram in the past, I interpreted it also as clocking the blade rotation position.
