Hey guys,
I picked up a B7200D hst in January, and overall it's an awesome-stout little tractor. Ive put around 60 hours on it (it's got just over (1000), and now that the warmer weather is coming around I'm starting to perform regular maintenance procedures. PO said he stayed on top of it regularly so I wasn't concerned..until now.
-Engine started leaking oil pretty bad, took a couple components off the engine and sealed with RTV and did an oil change. All seems good now!
-Tons of smoke on startup in the colder weather. Replaced glow plugs and decided to change the fuel filter only to find it was ORIGINAL!! It was so gummed up it started caving in on itself. Could not believe it - tractor starts so much nicer now.
-Went to change out the front diff/hub fluids. Hubs looked great. The front diff.. had water pour out the drain, followed by a molasses like sludgey oil. WTF. Must have been original. Filled it up, ran it, flushed it, filled it up again. Need to flush and fill again soon.
And finally! I went to change out the hydraulic/trans fluid and clean the strainers yesterday. The fluid looked nice and clean on the dipstick, but from everything else I discovered I thought it would be wise to change it anyways. PO probably used UTF or something. The fluid was clean, but I found quite a bit of metal shavings on both filters, and the hst filter was pretty plugged up.
Can anyone tell me what the metal shavings are from!? Is it safe to run the tractor? I spent an hour cleaning the filter yesterday. I used acetone, brake cleaner and even power washed it. I got it a lot cleaner, but I'm thinking about replacing it. Put filters back in, topped off with Mobil fluid 424 and ran it. What a difference it made on the hst trans. I'm really sorry for the long rant, just a bit peeved at the moment. Thank you guys.
