Piling Pelion on Ossa
Gene Blister
2019 Kubota B2601, FAL LA435, Snow Blower BX2822A, Land Pride rear blade RB1572
Aug 4, 2019
84
20
Cocolalla, Idaho
It was time to take the snowblower off Bessy II and reattach the LA435 “Quick Tach” FEL. Everything was in readiness, I felt confident it was going to be as easy for me as it was for Neil from Messicks:
“I won’t even have to get off the tractor seat!” :D
The thing about leaving a heavy implement on gravel, tottering on two tiny support legs, is that those legs quietly and steadily sink into said gravel over the course of a wet winter. :eek:
I got Bessy lined up for rendezvous and docking and found the loader’s arms about 4 inches too low to slip over the tractor’s support pivots. So low that I couldn’t get close enough for the quick and easy 4-in-1 hydraulic coupler to connect to the hydraulic feeds. :(
I tried lifting it by the arms to wedge something under the bucket (my chiropractor says with therapy and time the pain will eventually end). :eek:
I disconnected the bucket thinking to remove some weight and change the balance point. That did no good and now the designed way to raise the tractor up under the support pivots is gone.
I pulled out the trusty farm jacks to slowly lift the arms high enough to slip the front wheels under the arms, remembering to put a 2x8 under the jack so it would not join the loader sunk 4 inches into the gravel. No good. The loader has exactly one place to put a jack that won’t damage connectors, articulating pins or the hydraulic pistons, and when the arms are raised a bit, the whole jack-supported machine falls to the side. :mad:
Short of using a crane to raise everything, which won’t work anyway because this is all under a shed roof, does anyone have any suggestions? I’m paralyzed without the FEL and loader forks.
5,235
1,017
You need to get a 4 x 4 or similar between the two lift arms or frame so you are lifting one end of the complete loader at one time. With a couple of tries you will find exactly where to jack so that the loader is balanced side to side.
Goal is to get the FEL supports out of the gravel and unto a plank.
Then reattach the bucket.
SidecarFlip
Banned
555
I regularly set off my loaders, both of them in the side yard, on the grass. same with my batwing, my rake, balers and disc machine. Snowblower as well.
Learned a long time ago that a length of pressure treated 5/4 deck board cut about 12" long, makes a dandy foot for just about any implement and they don't ever sink.....:eek:
Enjoy your predicament. Bet you do it differently next go around.:D
hope to float
L3450
Feb 18, 2018
474
61
Ireland
Its just an idea. If you anchor the front of the loader (by driving some pins into the gravel) would you be able to pull the back of the loader from the front with your tractor. this should lift the back of the loader and allow you to put something under the legs to keep them up. then reverse the tractor until the loader is resting on its own. Unhook the rope and drive around to the back and attach the loader.
BigG
Sep 14, 2018
1,951
770
West Central,FL
On your equipment list you are showing a rear blade. Could you attach that to the 3 point and use the top of the blade to lift the arms until you could prop it up and turn the tractor around?
6,372
Come along, on a board in the rafters will get it done. :D
200mph
Mar 3, 2017
1,228
61
PA
Is there a way to connect a temporary hose extension, so the tractor hydraulics can be used to manipulate the loader arms? After raising, remove the extensions and connect as usual.
Palmettokat
M6800, B2710, L6060, Volvo 5 ton excavator and implements.
Apr 21, 2020
251
53
South Carolina
If you don't have a come along heavy ratchet strap will also work.
Different approach, can you lower the front tires air pressure enough to get them to line up with out having flat tires? You could also inflate the rears more than normal to help tilt the tractor.
3,678
connect the hydraulic lines and curl the bucket. That should lift the back ends of the loader arms. Sometimes you have to also "lift" the bucket using the loader control which will push the back end of the loader arms rearward toward their mounting position on the tractor.
Trust me, use the loader control to reposition the loader arms into their mounts.
