Water somehow getting into Bush hog Gearbox
aaluck
Oct 9, 2019
946
771
Snowdoun, AL
I purchased a used Bushhog 286. When I got it the first thing I did was empty the gearbox. (The photo shows the first drain of my finish mower I got with it, but the same as the 286). What came out was a cream colored oil--obviously water had gotten in. Because there is no drain hole I sucked out everything I could.
I filled it back up to the check hole. Just enough so that it seeped out a tiny bit and put the check plug back in. Wrapped plumbers tape round the threads of the check hole and fill hole. Used it twice, over two weekends and after I was done the second weekend I decided to check the oil to see if any needed to be added.
When I opened the check hole cream colored oil came POURING out--so obviously the fluid level had increased a great deal over the two weeks. The bottom seal shows no sign of leaking. The PTO seal shows no sign of leaking. The gasket around the top of the gear box looks in great condition--still has original paint on it.
Any ideas on what could be going on......?
5,235
1,017
BigG
Sep 14, 2018
1,951
770
West Central,FL
Are you storing it out side? Hooked to the tractor?
My hog hangs out of the cover so I cut a plastic bucket to fit over the gear box and set the tail wheel up on a block so the rain water can not run down the PTO shaft to the seal just in case.
Also there is not much oil in the gear box so the new oil may be contaminated by the water from the first time?
And I am with Dave the oil may be change colors as it entraps the air but does it expand enough to pour out of the gear box as shown?
Maybe draw some of the oil out of the gearbox and watch it in a glass to see if it separates.
aaluck
Oct 9, 2019
946
771
Snowdoun, AL
Read some of the posts on the following forum and I think you will realize it is not only water that can produce foam.
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2111537
When you next remove the oil, place it in a glass container and let it sit for a week. Any water will migrate to the bottom of the glass container.
I doubt any is getting in.
Thank you both for the replies. Very informative and explains (maybe) the color. But my question is the same as BigG...Why is the oil level rising to the point of it pouring out of the check hole, when it is only filled to the bottom of the check hole?
NHSleddog
B2650
Dec 19, 2019
2,149
1,831
Southern, NH
Micro bubbles of air will increase the volume and can affect the color if you get enough of it.
freewheel3
Mar 9, 2013
334
Alberta
Plus, if it was cold oil put in a cold gear box, the level will increase once the oil and gear box warm up. Not sure if it would account for that large of an increase, but it will account for some of it.
SDT
multiple and various
Apr 15, 2018
3,251
1,041
SE, IN
Condensation due to thermal cycling.
This is the primary reason why it is recommended to change the oil every two years or so.
Because of the lack of a drain plug in the lowest part of such gearboxes, much/most of the water remained in the bottom after you removed what oil you could.
I sometimes add a bit of "Dri Gas" to gearboxes, transmissions, etc., a couple of weeks prior to changing to absorb as much water as possible prior to changing oil.
SDT
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
It's almost impossible to get all the old oil out of those gearboxes. May have to change it several times before you get it clean.
Also need to make sure the vent is open so it can breath while it's being used.
aaluck
Oct 9, 2019
946
771
Snowdoun, AL
Thank you all very much. I feel much better about it now. Ill use all of the suggestions and check it before and after (it has cooled down) and see.
Thanks again
Pau7220
Aug 1, 2017
785
278
Scranton, PA
Don't forget the water will be on the bottom. That's why "sucking out" doesn't work.
I lift mine up with the loader and a chain so the drain plug is down. I'd stay away from any alcohol based drygas as it WILL damage seals. If you need to flush use mineral spirits or kerosene... at least they're petroleum based. What lube does that unit call for? If regular gear lube, upgrade to full synthetic. When you get it full and clean, I'd leave it standing on end to really see if that top gasket is doing its job.
NHSleddog
B2650
Dec 19, 2019
2,149
1,831
Southern, NH
I have an old one that I flip up and over to drain. Used to use chains now I use forks. Full drain every time.
