Hydraulics help Kubota b2410
tunin
Kubota B1-17, B2410, STW40, Antonio Carraro SRH9800
Jun 23, 2013
229
55
Medjugorje
Hi guys, U am fabricating an under stock ripper for soil, all is pretty much done except with the setup I purchased for hydraulics, I have one high pressure hose/connector that plugs in to one of my tractor connectors but the other plug is hte same but low pressure (return...
Being that all of my plugs are pressurized, I need to figure out where to return low pressure fluid.
Some photos attached:
Thank you.
9,474
The cap above the center link would be a good choice, that will dump fluid right back into the case.
I don't know what that block is for, it looks to be both pressure and possibly a return but I can't tell, our tractors don't have that block.
tunin
Jun 23, 2013
229
55
Medjugorje
Thanks mate, I was thinking the same thing, but I was hoping that one of these ports on the distributor would be low pressure, to make everything a bit cleaner... was gonna add another plug, perhaps a male on the tractor and female kn the other side so no confusion on low/high...
I need ot do something soon, as the season is here for my vineyards.
tunin
Jun 23, 2013
229
55
Medjugorje
Wow, thanks am illion man. How did you dig this up :)
So if I understand this correctly (English is not my language). I can connect the return to the C port on that block?
Again, thanks a million.
I believe this may help
