Somehow the rear oil cap situated at the back of the tractor (B2650 HST) between the two lift arms came out. It's stored under cover and I don't think its been missing for long, otherwise I would have noticed. I did however get some water in there when I was spraying it off before doing some routine maintenance. Not a lot but enough to cause concern. So my question is what to do?
My thoughts are:
1. Leave it open in hopes that it evaporates.
2. Over fill with hydraulic fluid and hope the water gets pushed out
3. Change the fluid - don't know if this is necessary and could potentially
expose more parts to water.
4. Something else I'm not thinking of
Thoughts?
DON’T RUN IT!
HOW do you KNOW?
How do you know you got water in it? If you RAN the engine with water in the hydraulics then the water will be mixed-in with the hyd-fluid and will likely turn “milky”. That would be bad and will be difficult to clean out without multiple hyd-oil changes.
IF you got water in it, then the water should settle to the bottom of the oil. But predicting how much and where it settled is not something easily determined. Presumeably the drain plugs are the lowest point. If it were mine, I think I’d drain a gallon or two out after a few days of sitting still....and see if I can find any water in it.
If I DID find water I’d do a complete changeout of the system. If not then I’d run it awhile and then check to see if there’s any indication of water having mixed into it.
Full Disclosure: I’ve never actually done this in a tractor, but I have experienced it when another vehicle was submerged in a stream-crossing. The hydraulic system fluid (a red H5606 hydraulic oil similar to transmission fluid) became very “pink” or “milky” . This was many miles deep into a forest and we had no choice but to continue operating until returning to civilization, where we deliberately overfilled/overflowed the system by pouring several gallons of new hyd-fluid into the fill-neck while the engine and pump was running, until the milky appearance returned to solid red. It was not the best way to do it, but it worked and had no issues for more years of operations. (This was back in the early ‘60s and EPA had not yet been created.)
