Clear Hydraulic Dye
BigG
Sep 14, 2018
1,953
774
West Central,FL
Can the red dye that they add to diesel fuel be added to the hydraulic fluid with out causing problems?
The site glass on my L2501 is just about useless because the oil appears to be clear.
Wiping a dip stick, from a TL80A, on a brown paper bag does not always work well.
3,816
Whew! I was afraid it was gonna be GREEN!
B737
LX3310
Jun 9, 2019
2,022
2,205
Can the red dye that ... to the hydraulic fluid with out causing problems?
@BigG did you end up using the MT3668 John Deere dye that Ken suggested? im considering adding it during my next service.
old and tired
1,919
1,297
I put all of it in but you can definitely use less since mine is very dark. Try 1/4 and if that's not enough, add another 1/4...
tradosaurus
Kubota MX5400 HST, Land Pride RCR2660 , EA 60" Xtreme grapple, EA box blade
Mar 7, 2019
97
71
Texarkana, Tx, USA
Receive my JD hydraulic fluid dye the other day. The bottle it came in was about 1/3 full and the instructions do say to empty the contents into the hydraulic reservoir. I'm guess there was about 2 oz?
Definitely works.
