Steep trails-
I am getting mixed reviews on how to tackle my project. I am hoping to avoid too much experimentation so figured I would post here, to see if anyone has tackled this before.
Issue: Gravel washing out/eroding on Steep Trail. -Need a solution. Trail consists of Mirafi 140n Non-woven fabric with 5/8" Minus gravel over the Top.
Goal: Fix trail with a long-term solution that will work.
We use this trail primary as a path for our quad, and sometimes BX tractor. For the quad, it is very passable, but since its steep, my quad spins and makes ruts in the gravel; add seasonal rains and we have all the gravel down at the bottom of the trail.
Looking back, the fabric was probably a mistake too.
Possible Solutions:
Concrete -drive path
Asphalt Pavement -drive path
Plastic permeable Pavers such as: https://standartpark-usa.com/products/easypave-grid-grass-gravel-paving-system.
Portland Cement Mixed in with gravel to "lock it up."
Asphalt would be the most difficult to do. In fact, IHMO not feasible due to access, transport, and compacting.
Concrete remains a viable option, but would be extremely expensive when calculating the mud, pumping, forming, and finishing.
The plastic permeable pavers are on my A list right now. you can fill them with gravel, dirt, or bark for that matter. While not cheap at $2.50/ft, these would allow for water passage (in theory.)
What I dont know is if gravel will stay in the cups as the quad passes over? Filling them with dirt could pose the risk of making a slide with a nice tractor trap at the end. Not having ever used these, I simply dont know if it would be a solution or not??
Simply Mixing bags Portland cement in with the gravel. Obviously, the Cheapo Home Depot fix of the group. I have read where this has worked for some people, and where it has not worked at all. There is a not a lot of info about doing this. My fear is that I would just end up with ugly concrete crumbles and would need to start over again.
At any rate, if anyone has tackled this before I would love to hear your thoughts and opinions on that matter.
Possible Solutions:
