Hello folks, new member here and I just inherited an old B2400 from my dad. I've ordered some manuals but they're not here yet and I have a couple of operating questions that maybe someone here can answer.
The tractor is an old B2400, 2WD with HST, and has a belly mower, bush hog, spring rake and a trailer.
I'd also appreciate any tips and guidance for this model that any of you might offer since I intend to keep this little tractor 'til I'm gone too. Thanks in advance.
- First of all, there's a heel pedal on the left side that looks like a mirror image of the reverse engage pedal on the right side. What does that do?
- Second, the 3PH hydraulics are mostly non-functional though occasionally they will go all the way to the top or all the way to the bottom depending on the control lever position. Any suggestions of things to check/replace?
- Third, this tractor exhibits the occasional low battery won't crank problem that I've read a little about. What's the best way to correct it?
- Fourth, how are the brake pedals supposed to unlock once you've set them?
