The injector thread specs in the cylinder headWhich thread - there are 3 different threads depending on the part of the injector you are interested in as far as I know.
The motor is stuck. I wanted to force diesel fuel into the cylinders to loosen the ringsKnowing what you need the spec for would help a lot!
Like i have stripped / crossed threads that I need to tap.
or
I need to find the proper compression adapter.
or
I'm looking at making a air compressor out of and old engine and want to tap off the ports.
Awwww, this is why info is a good thing.The motor is stuck. I wanted to force diesel fuel into the cylinders to loosen the rings
Well it might be negative advice to you, but it's good and safe advice for the OP.pet peeve of mine is when a request for information is posted, and the replies are negative advice.
I wish I knew what the thread size is for a D950 injector.
What I do know about them is that there are no adapters that fit in the "Harbor Fright" style compression testing kit ;-)
Pardon me sir, your first sentence is puzzling, was there some negative advice? If so would you be kind enough to identify it for me? I'm keen to learn and to offer constructive advice, what was negative about any of it from me or Wolfman?pet peeve of mine is when a request for information is posted, and the replies are negative advice.
I applaud your effort and different thinking, but it probably won't work, the last engine that was stuck like that, it took a sledge during the rebuild and a 2x4 to break the piston loose.Its already been soaking for six months. I wasn't going to use high pressure, I figure 100 PSI might help loosen the rings
