Does anyone know what size Fumoto valve will work on our Kubota's? I have a 2004 L5030 and the oil drain bolt part number is 16427-33750, but have no idea what MM size it is.
I'm with you, no doubt i would oil down the property after it ripped one of those off. I am constantly having to get the chainsaw out to cut limbs out from under the tractor while clearing the property.I just had to look this up and see what a Fumoto valve was
Now that I know...Why would you want one of thease on your tractor? My thoughts are while you are operating your tractor it could get caught on something and rip it out and loose all of your oil. On a car you are not expected to be off in the field, ditch or whatever.
If you go to Fumoto's site they give a sizing for most engines. You should be able to get the right size from that.Does anyone know what size Fumoto valve will work on our Kubota's? I have a 2004 L5030 and the oil drain bolt part number is 16427-33750, but have no idea what MM size it is.
