Hard line damage
E/S
2009 M8540HDC 4x4 w/ Cab
Jan 6, 2010
251
Reno, NV
Hooked a tree limb with my loader and damaged my hard line.
My question is do I have to replace the hard line, I'm scared to try and bend it back in place.
E/S
bruceatlam
B20, FEL, box blade, flail mower
Aug 20, 2009
410
Camarillo, California
Does your loader work OK? Doesn't look like it leaks?? Is it going to rub on anything?? If the answers are yes, no and no ---- leave it alone. Otherwise ---- I would replace the line.
Kubota Newbie
Dec 28, 2010
533
81
Mount Vernon, Ohio
To bend it back into position without breaking it you'll have to remove it, clean it of all oil residue and heat it. Otherwise it'll probably crack.
CobraTom
L5030, L3430, L4310, L3410, B3030 , R510 currently..
Sep 19, 2011
126
Ontario
Any loss in lifting power?
If it were pinched, it would not lose lifting power (PSI), but rather lose speed (GPM), the same way as using a smaller than appropriate diameter hose.
E/S
Jan 6, 2010
251
Reno, NV
I have decided to guard the kink and order a replacement line.
Thanks for your input.
E/S
