B2650 with hydraulic front blade problem
Slammer
B2650 cab
Oct 16, 2019
9
Loveland, CO, USA
I have a new B2650 and new B2775 hydraulic front blade that attaches on a mid mount subframe.
It has difficulty when I position the plow to the left. It moves to the right with no difficulty at all.
The only way to move the plow to the left is by going right first, then very lightly push to the left.
I’ve had it in the shop already. They replaced the hydraulic cylinder and said just push it left slowly. WTH?
Anyone else with this issue?
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
This sounds like that Regenerative Dump thing..... Someone with more hydraulics knowledge will chime in.
Slammer
B2650 cab
Oct 16, 2019
9
Loveland, CO, USA
I mentioned that to the tech at our Kubota dealer. He said regen only deals with exhaust. [emoji30]
I think I may have to take it elsewhere.
6,356
First go back and slap the tech because he has no clue what he's doing
All new FEL valves have regenerative or regen function!
Your problem is regen, yes your loader valve has regen, or also called fast dump, or speed dump.
On other valves all you need to do to make it work is push the control farther to the left, there is two detents you have to pass the first and go to the second detent.
https://www.messicks.com/school/kubota-la534-front-loader-removal-operation
"There's also a float in the dump circuit as well and you can feel a small detent in there that. What that does, is when you go and dump your bucket down you can throw the whole way over to the side into a speed dump position that will simply open the valve up and let the bucket flop right over and go. While you're working this stick you can also pull into the corners and stroke those functions simultaneously. This is one of the things that Kubota does best."
Slammer
B2650 cab
Oct 16, 2019
9
Loveland, CO, USA
We both understand the detents associated with it.
As far as “regen”. He said that term was only associated with exhaust and there is no reference to “regen” in the Kubota manuals when discussing hydraulics.
I don’t know... don’t really want to argue that point.
I’d just like to figure out what part is malfunctioning or hooked up incorrectly.
After it warms above the -2° that it is now, I may hook up the lines in reverse. I know it’ll go left when I push right... and vice versa. However, I’d be curious if there will still be a hang up on one side. And if it’ll be on the opposite side.
6,356
Slammer...
Look at my post count... I didn't get there by giving out false information! ;)
Slammer
B2650 cab
Oct 16, 2019
9
Loveland, CO, USA
Slammer...
Sorry if it came off that way... that wasn’t intended at all.
I was referring to arguing with my service tech. He doesn’t seem to really have a clue.
Anyone willing to take the time and help others out on a forum are ok in my book!
Again, thank you very much for the info.
6,356
It's cool! :D
I try and help anytime I can, and there are a few dealers and techs that like blowing smoke. ;)
SidecarFlip
Banned
554
It's cool! :D
You are that, I can attest to it. Thanks again for the LED link, they work fantastic. Bought 2 sets and I think Bulldog got a set as well.
The P30D base is a very odd base and finding a LED replacement is like fnding a needle in a haystack.
Wolfman comes through again....:):)
Slammer
B2650 cab
Oct 16, 2019
9
Loveland, CO, USA
Well... the first time I called the dealer I said, “You should replace the hydraulic lines. It seems like there is something that keeps clogging the return.” And I asked them just to bring a couple complete lines. It would’ve taken maybe 10-15 minutes to throw on a couple complete lines.
They picked it up twice and had it in the shop two weeks (one week each time). They replaced the hydraulic cylinder the first time, which didn’t fix it. The second time they replaced just the lines (kept the old connectors on). Still didn’t work. Then they decided to replace the connectors. Finally found the problem. It was the little ball inside the coupler (poppet valve maybe?) It was marred and would occasionally not allow fluid return.
Had they just brought a couple complete lines, replaced them on site, it would’ve saved so much hassle.
