Hi all! I am new here I have always owned KUBOTA and have never had a problem until now- I just bought a Grand L6060 tractor and a L4474 snow blower- I installed the snow blower my self my problem is when you have the chute turn left it goes with out a problem - but when you want it to go right it does not move until you move the loader joy stick into the detent or dump position but before you get into the dump position you can hear the motor load down a little bit- now I know when you hear that the hydraulic system is dead heading I need to know if this is normal or if anybody has run into something like this- my dealer says it is normal but I dont think so. I have even removed the gear that turns the chute but the problem is still there. I even took the hydraulic hoses off of the chute motor and started the machine and moved the loader joy stick and one way fluid comes out of one hose and nothing out of the other and when I moved the joystick the opposite way fluid was still coming out of the original hose and very little out of the opposite hose -then when you go to full dump or detent fluid stopped coming out of original hose and then started to come out of the other hose. Does any body know what this could be or where I should look. Any help would be greatly appreciated. Thanks to all...Chris
