I'd like to add a bale clamp on the front end loader of my M4500DT. Currently it has one one-way valve, and one two-way valve both used for the front loader (single acting lift cylinders and double acting curl cylinder). So I need to add a two-way valve for the double acting bale clamp but I'm not sure of good options for doing this despite having done a bunch of internet searching. The hydraulics are open circuit, 2700 psi max.
I'd prefer to keep this old beast looking original so my first choice would be to add a second Kubota 2 way valve in the current 2-valve bank. But according to my research I can't stack a third valve onto the existing 2 valves (the existing 2 way valve is sandwiched between the one-way valve and the gearbox casing and the ports don't look like they are compatible with stacking valves).
Another other option seems to be to add a mechanical joystick for the loader controls but I am uncertain about the terminology and do not want to end up getting the wrong one, so I am calling for help!
Does anyone have any suggestions or can refer me to any sites about whether:
(a) a mechanical (non-electrical) joystick is available that will do 3 functions (single acting lift, double acting curl, and double acting clamp) all in one joystick? If so, what's the terminology for such a thing so I can find it on the internet?
(I don't need a float function but would be happy to have it. My only objection to electrical joystick is the additonal complexity. I'm reasonably confident that I can mount the mechanical joystick where the plumbing won't get in the way.)
(b) how do I plumb the joystick into the existing system so I can still use the existing 2 valves for other functions without having to isolate the joystick from the 2 valves, not have a separate supply and return line? Would I have to make a power beyond adapter?
Thanks in advance for your help.
