I guess I have to ask WHY someone would buy a BX23 when you should simply buy a REAL tractor or REAL lawnmower...and WHY would you need to use an APP for the weather when you can simply look out the window? WHY would you even need a phone and GPS on your lawnmower?Have to ask WHY ?
Seems rather 'silly' as you know what it's like outside when you hopped into your tractor....
Any external sensor needs to be properly mounted( not in sun, not on metal, not in wind, etc.) I spent 3 decades doing remote temperature control systems...sigh...
If you want to go 'hightech' cut or download an 'ap' to read your current GPS location then grab the 'current' weather information plus stats from database, process through some 'math' to get close real temperature.
I guess I'm interested what the actual ambient temp is at the location I'm at. The phone / GPS temp readouts are based upon the temp located somewhere else and I find can vary considerably from what you see in your car.Have to ask WHY ?
Just because you don’t want one doesn’t mean it is wrong for someone else to ask the question. If you don’t like what an poster is asking, don’t reply to the thread, it’s as simple as that. Troverman, I agree that the phone apps are useless around here, because their data is usually based upon some airport that has temperatures 5-10 degrees different than where you are located.Have to ask WHY ?
I seeI want something that looks nice and as built in as possible.
I have a nice weather station at my house, mounted on the peak of my garage and transmits into the house. Wind speed / direction, rain, temp, humidity, dewpoint, etc, etc. It does connect to wifi and keeps historical data. However, my tractor goes to job sites all over the place, many with no cell signal. Its nice as you mow for 6 hours straight to get an idea of how hot or cool it is. I only want the temp. I just figured if I can have it in my truck, why can't I have it in my tractor?
Believe me, I'm thrilled to death this tractor has a clock, let alone a readout showing your fuel consumption, DPF percentage full, etc. It just seems since Kubota already has this nice display in the dash, why not spend an extra $10 and add a temp probe somewhere and display this info?
Interestingly, on Ford Super Duty trucks, the temp probe is located on the bottom of the passenger side mirror. On RAM Heavy Duty trucks, the probe is located in a small channel under the left side mirror. Of course, these trucks all come standard with large towing mirrors that stick out further, and have places to hide a probe. I prefer these locations, because the probe is mounted in plastic away from ambient engine heat, and higher off the ground to be a little less affected by road heat....On cars the probe is almost always located in front of the vehicle on the outside of the radiator. Most vehicles also only update the temperature once you hit a certain speed - my F150 is like this.
