BX hydraulic backhoe thumb build
BXHoosier
BX24
Jan 21, 2018
512
630
Indiana
I have decided to build a hydraulic thumb for the backhoe on my BX24. I recently added dual rear remotes with the intention to use them to control a thumb. The 2 spool valve hooks up inline with the backhoe. Today, I mocked it up with 3/8” plywood. The upper mount will be welded to the dipperstick.
BigG
Sep 14, 2018
1,953
774
West Central,FL
If your metal working is as good as your wood working I think you will be golden.
stano
24
Ontario
Looks good. I had another look at your pics and you are fine. Hence the edit of my post.
11,008
I think you'll find out very fast that the rear remote don't work very well for BH operations, trying to grow another hand and arm to run it, is pretty hard to do.
You would be very easy to add a Electric valve that that is controlled by a button on a BH joy lever, that would keep your hands on the controls, not trying to reach behind you to run it.
BXHoosier
BX24
Jan 21, 2018
512
630
Indiana
I am sure it will be a little awkward but I am mainly just doing this so I will not have to climb off to adjust the thumb like I do with the manual thumb I have now.
6,285
NICE !!!! Great thing about wooden prototypes is that if they don't work, they can heat your garage. Whole lot easier drilling wood than steel, let alone all them teeth !! CLEVER ram 'in AND out' locations !! I'd like to 'borrow' that method please !
Jay
js5020
BX23S
Jun 27, 2018
75
PA
Nice idea, I'd like to have hydraulics on the thumb myself for the same reason I don't want to get off and manually adjust it.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
604
617
Lake Almanor, Ca
You will be very happy too. I converted mine too...most handy tool I have...
I would post a couple pics...but the site is not letting my...again....
6,285
Saw a TLB that had 2 'saw toothed' plates bolted onto both sides of the boom. He could easily grab and hold onto 20' lengths of 12" culvert.
Seems like a simple, easy,cheap method. If there was a market it'd be quick to CNC the parts.
BXHoosier
BX24
Jan 21, 2018
512
630
Indiana
I ordered the cylinder and it should be here tomorrow or Wednesday. The upper cylinder mount is made and ready to weld to the dipper stick. A friend drew up the thumb plates for me and he is going to see if his friend can burn out the pieces on a plasma table.
BXHoosier
BX24
Jan 21, 2018
512
630
Indiana
What size is the pin and what kind of steel did you use? Looks nice!
Thanks
The pin is 1 inch cold rolled steel. Cold rolled has a single shear strength of 40,000 psi so the 1 inch pin in double shear is good for roughly 62,000 lbs.
5,529
Wildfire is a member here and if you follow his facebook page, he has come up with tons of mods for the big "K" tractors. And I do believe he sells some things as well. Top quality work and a great guy
Wildfire
Thanks Skeets for your kind words. Your not to bad yourself my friend :)
BXHoosier
BX24
Jan 21, 2018
512
630
Indiana
Paul, your videos are great. I watched your thumb build and it gave me some info and ideas for my build.
BXHoosier
BX24
Jan 21, 2018
512
630
Indiana
My thumb plates are programmed into the torch table and ready to cut. Hopefully I will have them early this week.
