Currently working on some hydraulic issues with the M125X tractor and have questions regarding hydraulic filters. The tractor has three spin on elements. Two suction, one for each pump, and another one on the lift housing. The parts book lists it as a hydrostat (or maybe it was HST)filter element. I'm curious as to what this element does. Where it's mounted it doesn't seem likely that it's associated with the transmission system functions. It's available OEM and from other replacement suppliers, all in the $40 range, so it's probably not a high pressure item. Is it simply a return type filter for exhaust fluid from the lift system?
