bx23 no power to starter
sardillim
b2650
Nov 24, 2019
126
62
Easton
check the safety switches , pay close attention to the switch under the machine for the forward/reverse pedal
leveraddict
Apr 1, 2019
905
590
NEPA
I had the same problem. The white plug going to the starter can be pulled apart far enough to cut power while still being locked together. I know it makes no sense! Try pushing it back together. When this happened to me it went off and on for two weeks. It would start no problem some days and others I could not get it to turn over. I checked and cleaned the battery terminals and spent a lot of time checking all the safety's. I finally called the dealer to pick it up. I found the problem that day!
5,725
Gee thought I was the only one that happened to.... as LA says, check the 'control wire' connector on the starter. Once I pushed it on, we were 'good to go' ! I used a tyrap to secure it so it can't fall off.
leveraddict
Apr 1, 2019
905
590
NEPA
Jay you too! I thought I was the only one! Ive mentioned this plug in a few posts before just hoping it would help someone!:D I cant tell you the grief that plug caused me!
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
169
Hardisty, Alberta
I made a very long, expensive service call one time to find this wire off! Needless to say it is the second thing I tell customers to check these days after ensuring the PTO lever is right back.
5,725
If Kubota had supplied a good, readable wiring diagram in the manual, it'd be a 5 minute..doh--that's easy to fix.. instead of a couple hours. Even the downloaded WSM schematic is UNREADABLE..sigh...
