So I was using my BX2750D with the 2751 quick connect when I heard an awful rattling noise coming from the front of the tractor. Next thing I know the PTO shaft came flying off the output shaft on the 2751 and was flying around under the tractor. I immediately turned the PTO off. I looked under the tractor to see fluid leaking out of where the PTO extension shaft connects. After looking further I saw it was the oil thats around the PTO Shaft leaking all over my driveway.
Is this seal easy to fix? I get the feeling now that my PTO extension shaft is bent that I will need to buy a new one. I just recently changed the output shaft from 14 7/8" to the 11" because I have a Bx1860. I made sure 5" was portruding out of the edge of the bearing. Why would this happen?!?! any help would be appreciated.
