Help Please L4150
STEVEKCMO
l4150 camery, rav4, tundra, mr spider
Nov 29, 2019
HOLDEN
I have an L4150 and the stopper on oil dipstick has come lose..I need the distance from the bottom of stick to bottom of stopper, so I can re set it..thanks.. in inches please
7,682
If there is no clue on the stick where the stopper was, and you get no response, you may need to do an oil change on level ground and measure it yourself.
11,197
Engine or Transmission?
And if it's done that you would be better off just getting a new dipstick! ;)
STEVEKCMO
Nov 29, 2019
HOLDEN
oil stick. hopefully some has a stick and can measure for me..tried to measure but can not tell were it should be..thanks for the picture, but can not figure it out from that..have prices it out, at $50.00 with freight...p/n 17381-36411 on the original, it has a bend in it, that could be the diff.. / or ..17381-36410, do not know the difference between them? oil stick... really can not afford it at that $
.thanks for all the replies
7,682
Might send a PM to "007Kubotaguy" on this forum. He has many part for older L series tractors. Perhaps he has one he can mail to you.
If you decide to drain and refill and measure, a metal piece with a slot could easily be tacked to the stem with one zap of a wire welder! Or JB Weld it on.
11,197
rbargeron gave you the measurement did you miss it?
The original rubber plug is bonded to the stick with a super fancy method, super glue, you can use that to bond it again at the proper height. ;)
STEVEKCMO
Nov 29, 2019
HOLDEN
his was straight, my has a bend about 3/4 way up.i think that was the p/n diffidence
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Sounds like time for an oil change :)
I would end up over-engineering this issue if I had to fix it......probably include some threaded rod and a dip stick from my collection, and my electric glue gun.
[the collection is for making "dip stick" awards for some of the guys I work with]
STEVEKCMO
Nov 29, 2019
HOLDEN
thanks for the reply..there is a hole in side cover to put it in and out..no way a straight one would go in? can no one id the p/n 17381-36411 that is on it? is there not one owner of an l4150 on here...thanks all for replies
11,197
Steve,
There is no P/N 17381-36411.. where did you get that Number?
The only listed P/N for a L4150 is 17381-36410, through all sub models too, and it's a strait dipstick, it sounds like either someone has put the wrong dipstick in it or you have a different model than what you state.
I've only seen the bent dipstick on Industrial engines, has you engine been replaced at some point?
And you mentioned hole in side cover? What are you calling a side cover because Kubota only puts the dipsticks in the block on the side or directly into the oil pan, and that's not done on the tractors.
