Do you need a new hip or knee
5,687
3,447
I will here by add, should you elect to have a knee or hip replacement. Be sure you obtain an ID card for whom ever did it. This card will be used by TSA should you fly. These replacements will set off the alarms,,just sayin
Newlyme
M4900 w/loader, finish mower, tiller, auger, rake. BX24 w/loader, backhoe
May 27, 2015
637
74
Nelson Ohio USA
I have both hips replaced. At the airport I have to use the scanner not the metal detector.
When I go to the local Courthouse I use the only thing they have, the metal detector, and it doesn't even sound the alarm. When I asked the Deputy why, he said it was because the devices are inside of me. And this happened at three different Courthouses.
So I guess the moral of this story is, If you want to take a gun into the Courthouse just shove up your.....
dlsmith
BX2230, LA211
Nov 15, 2018
1,235
789
Goshen, IN
Yep, I have one for my shoulder replacement. Not that I intend to fly in one of those aluminum cattle cars anytime soon.
dlsmith
BX2230, LA211
Nov 15, 2018
1,235
789
Goshen, IN
It doesn't set them off because the parts are nonmagnetic, probably titanium, beryllium, stainless steel or ceramic.
Magicman
Oct 8, 2019
5,538
7,680
Brookhaven, MS
knotholesawmill.com
I just had a Total Knee Replacement on Nov 18th. I completed my in-home PT Wednesday, made my first post-op Doctor's visit yesterday, and began my outpatient PT today. So far all is well. :)
3,447
All the best, push your self past where you think you should stop, it will only help
Magicman
Oct 8, 2019
5,538
7,680
Brookhaven, MS
knotholesawmill.com
I am at 110 degree flexion and 10 degree straight. Since the bending is progressing nicely, the PT is concentrating on the straight leg. I have homework to do twice each day.
rogerwh0825
BX2660
Nov 14, 2017
46
Havana, Fl. US
Have needed a knee replacement for over 3 yrs now. They wouldn't do it until I got my BMI under 40. Starting in August I realized I couldn't keep going like this due to the constant pain and started serious weight loss. Lost 30 lbs and the Ortho Doc two weeks ago said let's go. Hallelujah.
Last week my regular doc said he wanted to take an EKG just to be sure. Of course he finds a PVC (I always thought that was pipe!) in my EKG and won't OK me until they can resolve it. Getting darned hard to walk.
Had both overnight Holter monitor and stress test back in June with everything then showing as OK.
