No, absolutely not worth it, my 60 series loader is about 45 seconds on or off, yea have to get off the seat to put stand up or down, connect disconnect lines. If getting off the seat is a problem, you probably shouldn’t be doing whatever you’re doing with the loader.
but still 45 seconds, zero leaks in 10 years, zero mounting problems in 10 yeas, vs what? 20 seconds on / off plus how much time cleaning up the oil mess and fiddling with replacing connectors, working with the dealer... frustration?
On the general topic of design/ quality of the BX
Glad I got the 60 series when I did. 70 series ROPS sucked, the common story at that time was bashing garage doors with the too tall and ugly looking ROPs. people cut them down, or bought the old 60 series ROPS and swapped it out. They moved the brake to the left side, but who cares, no one uses it except as a parking brake, I like it better on the right side to keep the left side more open for entry exit.
80 series loader sucks, new grill guard doesn’t suck but not as good, looks kinda ugly, old removable cowling gives better access than the 1 pierce hood, so in my opinion new hood design is not as good, optional drive over MMM sucks, takes longer to fiddle with, the 54” fine cut MMM not available (IMHO the best BX MMM deck). overall I think no improvements in 10 years, oh except they have better tie rod bushings, only improvement in 10 years.
The 50 series had plastic cracking problems and transmission jerky problems. The original bx2200 was good but there where later improvements like integrated loader valve, better bakes, better dash, better looking, better MMM.
I really think the 60 series was the peak, close to perfect.
If something changed and I needed a TLB or a higher HP BX, I would first shop for a low hours 60 series before going for an 80. Or go to the B01 series, would hesitate on those because they are too tippy, same width as BX but much higher. The other near perfect Kubota is the B2650/LX2650, don’t see anything wrong with those. Standard Ls have the split brakes on the wrong side. Grand L, very good, but very complicated computer controlled stuff, probably good for the home fixit guy.
Sorry for the rambling, but wanted to put that out, see what others think.
