The recommended Hydraulic Fluid for Kubota Tractors is SUPER UDT2 Fluid and is recommended for both the HSD and HST models but it is $140 delivered for 2.5 Gallons (See Amazon Link) https://amzn.to/36eP3Cf
OR
I have found the very best pricing for both the filter and alternative hydraulic fluid for my B7510HSD and have listed them below for your convenience. I chose the mid-weight ISO 68 (Summer Applications) for the hydraulic fluid as I am in Florida and if you are in colder climates then Kubota recommends the following: https://www.kubotausa.com/service-support/maintenance-schedules/lubricant-maintenance-schedule
Hydraulic Oil-Excavator and Compact Track Loader Summer or High Ambient Temperature Applications*** ISO 68 Only $55 Delivered for 5 Gallons/18 Liters https://amzn.to/34aFx0L
Hydraulic Oil- Factory Fill - Excavator and Compact Track Loader Winter Applications*** ISO 46 ONLY $48 DELIVERED for 5 Gallons https://amzn.to/2JrNqan
Filter Maintenance Kit for HST (hydrostatic transmissions) and fits these Kubota Models: Kubota B26, B7500, B7510, B7610, B2410 D HST (HST=Hydrostatic Transmission) and if you have a HSD model you will NOT use one of the filters in this kit. ONLY $68 Delivered https://amzn.to/32S6Dd5
OR if you just want the hydraulic filter only then Baldwin BT8902 OnLY $19 Delivered Amazon: https://amzn.to/2qJMTKk
Don't forget to change your oil in the front axle assembly at the same time: Lucas Oil 80w-90 Gear Oil, 1 Gallon Only $32 Delivered https://amzn.to/2NlNCJg
Hope this helps everyone a great deal as it took me my whole morning to find the best prices and best quality on these items. Good Luck!
OR
