Just installed a Charr-lynn 1.21 cu. in. hydraulic motor for the rotation of the discharge chute on my snowblower. I have a B7610 tractor and a B2781A blower.
After hooking up everything, I started the engine and tried to rotate the chute. It rotated in one direction but not the other. I swapped the quick disconnects and it rotated in the other direction but again not the other. It always rotates with the control lever to the left and will not rotate with the control lever to the right. It seems like the control valve is not allowing oil to flow in both rotational directions. Any help will be greatly appreciated.
