I never learn...
dlsmith
BX2230, LA211
Nov 15, 2018
1,268
850
Goshen, IN
Yep, it's always good to get a long neglected piece of equipment started again.
Any idea who make the dozer blade system? It looks kind of like a homemade system, but might be some kind if aftermarket manufactured unit.
Doesn't look like anything Bucyrus-Erie made back then though.
Good work, guy.
PHPaul
Apr 2, 2015
1,142
1,248
Downeast Maine
www.eastovershoe.com
Good work, guy.
I think it's the original JD-supplied unit. There's a tag on it, I'll check and get back to you.
BAP
Dec 31, 2012
2,920
1,032
It’s rated for 28.7hp at the belt and 23.7hp at the drawbar. I am pretty sure that John Deere made the bulldozer blade for them and it was an option.
3,088
When I was younger & had more time, I often was selected to fabricate replacement parts for restoration of old equipment- metal working machinery, cars, locomotives, aircraft, tractors, slot machines, pinball machines, clocks, and maybe my favorite, a WWII Army Jeep, completely original. (paint, lettering seats, pioneering tools, tires, 30 carbine rack, tool kit, blackout light shields, with 13 miles on the odometer, and it ran!)
I love the fact you're bringing the old girl back to life, and hope you keep us informed. Great read so far!
PHPaul
Apr 2, 2015
1,142
1,248
Downeast Maine
Good work, guy.
Tag on the dozer frame says it's a John Deere Model 62.
CaveCreekRay
Jul 11, 2014
2,631
105
Cave Creek, AZ
Unwrapped about a pound of electrical tape this morning. YIKES!
Now you know what wore out the treads.
dlsmith
BX2230, LA211
Nov 15, 2018
1,268
850
Goshen, IN
Okay, I just never saw one like that before.
Some people shouldn't be allowed to touch anything mechanical, or call themselves mechanics.
bucktail
Jun 13, 2016
1,260
191
MN
No kidding. A fix like that should require a pound and a half of electrical tape minimum.
dlsmith
BX2230, LA211
Nov 15, 2018
1,268
850
Goshen, IN
Ain't that the truth? I have used "field expedient" fixes to get through the day, but I fix it right when it gets back to the shed!
That's the difference between a true mechanic and a hack.
PHPaul
Apr 2, 2015
1,142
1,248
Downeast Maine
Got the wiring all replaced, added one of them new-fangled "fuse" thingamabobs, cranked it up and checked out the hydraulics, which I forgot to do last time I had it started.
After figuring out the valve setup it raises and lowers the blade frame, but EVERYTHING leaks and the fluid looks like chocolate milk. Add to my list: Remove, clean, dope and tighten all connections, drain and replace fluid, rebuild cylinders.
Doesn't appear to be charging (6.3v on the battery with it running) so I suspect the generator or regulator need some love. Regulator looked pretty new compared to the rest of the machine, but that doesn't mean much.
dlsmith
BX2230, LA211
Nov 15, 2018
1,268
850
Goshen, IN
If it's been setting a long time, the generator may need to be polarized again.
BigG
Sep 14, 2018
1,951
773
West Central,FL
According to Tractor Data the JD 420C is a 6 volt, positive ground tractor.
CaveCreekRay
Jul 11, 2014
2,631
105
Cave Creek, AZ
Skeets says you are gonna put Kragar mags and wide tires back on that thing instead of the treads. Any truth to that rumor?
PHPaul
Apr 2, 2015
1,142
1,248
Downeast Maine
Found some more presents when I drained the transmission.
Right side final drive off, wasn't too difficult. I'll start on the clutch pack but I have to knock off early today to go help a friend.
