You will have to lower the front axle enough so the drive shaft can be slid out above it.Attempting to remove propeller shaft and covering tube to replace oil pan on M95X.
have tube lose and both couple pins punched out but shaft tube will not drop enough to go by the front end differential rear bearing assembly? does it have to be removed?
I haven't ever tried to get the pan off that way but I have my doubts it is possible.Yes thank you very much for a quick reply , that makes sense.
I had contacted my local dealer and was informed the propeller shaft and tube would come out without unhooking the axle assembly.
Today I was going to attempt to unbolt the engine oil pan and see if it could be removed by pulling it forward and rolling it over the propeller shaft tubing, but this was probably wishful thinking
