leak on hydraulic line
Getorange
11
Portland,or,usa
Looking for some assistance with a leaky hydraulic line. Fluid is seeping from the top of the connection. Line doesn't show any impact. Any suggestion on stopping the leak without having to purchase a new line. The hydraulic fluid is seeping from the top of the seal.
Thanks
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
Thanks
The line is cracked inside the nut just behind the compression furrel. Not at all uncommon! I guess you could cut off the furrel and install a new one if the line is long enough but you are likely much better to replace the line. You could replace it with a hydraulic hose if there is enough room.
OlFerguson
4440, 1120D
Jun 1, 2017
189
11
I would say just replace it. Hoses that leak are usually just used well. There’s nothing really you can do to stop this. Just typical wear and tear.
