Hydraulic & Transmission fluid inlet
Tasha
3300SU
Sep 23, 2019
Eliot
The transmission fluid inlet is shown in my Kubota 3300SU manual, to the rear, and at a level below the seat. My manual does not show the hydraulic fluid inlet. Could it be that they both use the same reservoir? If not, where is the inlet for the hydraulic fluid? Thanks for the help: Tasha
nbryan
Jan 3, 2019
1,322
845
Hadashville, Manitoba, Canada
That's a common reservoir for the transmission and hydraulics for your machine, no? Checked your operator's manual?
Sent from my Moto G (5) Plus using Tapatalk
Tasha
3300SU
Sep 23, 2019
Eliot
nbryan: I understand that you checked the manual and you are confirming that the reservoir is common for both. Do I have your answer correct? Thank You.
nbryan
Jan 3, 2019
1,322
845
The operator manual is online.
https://www.manualslib.com/manual/914189/Kubota-B3300su.html?page=55#manual
From the linked page:
"Transmission Oil:
The oil used to lubricate the transmission is also used as hydraulic fluid. To insure proper operation of the hydraulic
system and to complete lubrication of the transmission, it is important that a multi-grade transmission fluid is used in
this system. We recommend the use of KUBOTA UDT or SUPER UDT fluid for optimum protection and performance.
(Consult your local KUBOTA Dealer for further detail.)
Do not mix different brands together"
There ya go! Have fun!
