I bought a used 2003 L5030 with LA853 loader. Control valve has YW232-0011 2 on the back of the unit. When loader lifts about 2 feet, it starts straining and both head end and shaft end cylinder hoses feel tight. If I loosen the shaft end connection and allow fluid to leak into a bucket while lifting, it lifts all the way. I have the head end of the lift cylinder connected to 1B and shaft end to 1A.
I pulled the control valve off and checked to see why I have pressure on the shaft side lift cylinder while lifting. I discovered the spool opens the shaft side cylinder port to the BY port on the valve, NOT the T port as I was expecting. The only time 1A or 1B opens to T port is when the valve is in float. Is this normal, or has someone put the incorrect spool in the valve?
Or, is there something I need to do with the 3 pt to allow it to release the pressure that seems to be building?
