B2650 with 60" mmm
SDT
multiple and various
Apr 15, 2018
3,271
1,055
SE, IN
Anyone else have issues with the holes to pin the mmm up not lining up real well? Whats the trick to pin it up?
Easy pin up requires that the deck be properly installed and adjusted.
Not all dealers do this.
SDT
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
I read that some need to be lifted a little to get them to align, mine currently go in really easy with 1/4***8221; self latching pins I picked up at Tractor Supply. Just a little wiggle and they are in. I also find it easier to install and remove when the loader is off, might just be my fat fingers.
howie70
BX2370
May 29, 2013
22
Shenandoah Valley, VA
SDT
I'm getting a B2650. Dealer called and said it was ready. I went by to check it out and noticed that the holes were not close to being lined up. So it hasn't left the dealer yet.
Dae06
170
11
Minnesota
I had the exact same problem. I had been using a jack to lift up the mower to pin it up. It was a real PITA! Along with that, the brackets in front of the mower where bending open and I almost lost the mower one day. I called my dealer and they picked up the tractor, replaced the brackets and re-adjusted the mower deck. It is now perfect. When I lift the deck up all of the way, the pins
go in perfectly. It obviously was not adjusted properly when I bought it.
TimP
B3000
Jan 16, 2012
64
Baltimore, MD. USA
I have a B3000 with the same problem.
I have a 60" belly mower and the holding pin holes do not line up.
I have not had a chance to fool around with it to see if I can somehow adjust it to make it line up.
PA452
B2650
52
Western PA
Mine arrived with the mower pinned up. I'll probably never pin it up again, as I prefer to just have the mower off if I'm doing other things. But yeah, on mine one pin was somewhat easily removable, but the other was very tight to get off.
I'm more worried about the front hanger. It seemed like that thing had some flex that wouldn't allow the pins get all the way through far enough to get the retaining rings through. I'm thinking I may need tools or help when it's time to reinstall.
Dae06
170
11
Minnesota
I take mine off after the last mowing of the year for snow removal and put it back on for the first mowing of the year and it stays on all Summer unless I need the extra clearance in the woods. I would not enjoy taking it off and on every time I use my box blade, tiller, rake harrow or any other implement. Pinning it up is a great function in my book. My 2 cents worth.
PA452
B2650
52
Western PA
For me, typically when I'm not using that tractor for mowing I'm using it for the FEL and backhoe and/or firewood. Frequently I'm on terrain where I might be banging the mower up if I left it on.
howie70
BX2370
May 29, 2013
22
Just to follow up, my dealer got it corrected and my my tractor was delivered just a day or so after I posted this. So far so good. I'm loving the B2650. Traded in a BX2370 which had been a great little tractor for me in the 6 years I owned it.
