Is dual aux hydraulics is worth the extra $1300
5,205
1,889
It sure helps resale when/if that time comes.
Is it worth it to you? Do you think you ever might need it? If you order without and then later find that you might need it, it's probably going to be more than $1300.
2,965
Does anyone have an opinion if dual aux hydraulics is worth the extra $1300 expense on a KBX 040?
Do you have a need for them? If so then probably worth the cost.
I added my own years ago for less than that, but prices increase. I have four remotes, but only use three of them. Three have check valves, one has float.
Consider if you want check valves in the remotes or a float function. Without check valves you cylinders will leak down over time. So an implement will gradually change position during use.
Float can be really handy sometimes. Do you need it? Don’t know...
SidecarFlip
Banned
554
depends on what implement you have or plan on having Like Henro, I have 4 sets on each tractor and a flow control valve for the upper set
