Ranger - you said the issue is rapid clicking while starting.
Does the tractor turn over when this is happening?
Obviously chim, Jim and wendol have encountered a problem with the pedal switch before, so I'm probably way off.
Doesn't a faulty/maladjusted switch prevent the tractor from turning over/energizing the start system with the L3200/3800?
I was wondering if it's a battery/ground/wiring problem causing the clicking sound (e.g., starter, solenoid) instead of the pedal switch, if that makes any sense.
Again, you guys all know better than I since you've dealt with it. I just took the problem differently, so wanted to throw it out.
At this point I hope you are all correct, because you have ranger's fix all figured out! That's one of the great things with OTT...."oh yeah, I had that problem and this is how I fixed it!"
