I'll have to respectfully disagree. Like Sidecarflip mentioned clay base grease can cause all kinds of problems. They bought us a barrel at the quarry because it was a little cheaper. Probably cost us $100k in bearings and down time. Just a small amount of heat and it will turn back to dirt.What ever is on the shelf. It really makes little to no difference.
Fair point, clay base is not on the shelves here so not a problem.I'll have to respectfully disagree. Like Sidecarflip mentioned clay base grease can cause all kinds of problems. They bought us a barrel at the quarry because it was a little cheaper. Probably cost us $100k in bearings and down time. Just a small amount of heat and it will turn back to dirt.
I don't have any issues with the Amsoil Off-road grease I use in cold weather but I do keep my gun in the house. If cold temps are a issue it also comes in NLGI#1 which would pump easier.Love the suggestions. Been looking for my next grease case - I guess I wanted ask w/ so much experience here about Cold weather specs? One of the suggested noted 40F or higher. And I run my gear down into the teens and negative temps here in MI. I'll check the mining/cont. brand noted ... but thought I would ask what ya'll thought about a cold weather grease and a summer time grease? 1 and the same... or two brands.
Your opinion and Lubrication Engineers opinions differ and in as much as they are considered by many in the heavy truck industry as the premier supplier of lubricants, I'll go with them...thank you.I am always suspicious of ***8220;Teflon***8221; additives in lubricants. (Also called PTFE)
In greases it may or may not be appropriate but in OILs is is virtually ALWAYS a bad idea! I***8217;m reminded of the PTFE advertised in certain engine oils and snake-oil engine additives. If it remains suspended in the oil after a few minutes it means your oil filter is not doing it***8217;s job and it means the PTFE particles are contaminating your lubricating oil and interfering with the oils***8217; purpose.
PTFE/Teflon is a low-temperature, low-pressure anti-friction material. It does not belong in oil or greases, IMO.
My statement was not made out of thin-air as an opinion. It was arrived at after careful reading of information published by lubrication authorities who have no money at risk in snake-oil additives. Bob is the Oil Guy is a good place to find reliable info links. But it doesnt take a scientist to recognize that the Inventors of Teflon, DuPont advise AGAINST its use in lubricants. And simple logic prevails against teflon particles suspended in oil that is filtered to remove such solid particles or where it would obstruct oil from reaching bearing surfaces.Your opinion and Lubrication Engineers opinions differ and in as much as they are considered by many in the heavy truck industry as the premier supplier of lubricants, I'll go with them...thank you.
Besides, I'm sure you alreagy know what has been said about opinions......
