B7100d get tire sizes
iangoround
B7100HST w/ L1630
May 13, 2019
39
Rochester, NY
Hi all.
I'm still plugging away on my repowered b7100. It runs and moves and works pretty good now, but I have a question about tires.
The seller gave me a set of 20x8-10 Carlisle Trac chief r4 tires that are on the front, and the rear is currently Goodyear xtra-tracs in a 31x15.50-15.
I know that's larger than stock, but I'm having a hard time deciphering what SHOULD be on there if I want another r4 tread on the back without putting the ratio too far out of whack so I don't cause problems with the 4wd.
Sent from my Pixel using Tapatalk
Missouribound
Jun 17, 2014
669
62
Missouri
According to tractor data. (tractordata.com) That machine came with either standard or turf tires.
Standard were: Front 6-12: Rear. 8-16
Turf were: Front 20.5 X 8.00-10. Rear 29 X 12.00-15.
Hopefully that will give you an idea. I'm sure your dealer will have a chart somewhere to see what is needed to keep the 4wd in good shape.
And if curious, tractordata.com has a lot of information for that and other Kubota models.
11,323
Jump the front tire size up a bit to make up for the larger rears, go to a 22X9.5-10
iangoround
B7100HST w/ L1630
May 13, 2019
39
Rochester, NY
I think I figured out how to do math finally.
FRONT: 6-12 RC: 68.9
REAR: 8-12 RC: 92.5
ratio: .7449
current tires:
FRONT: 20x8-10 RC: 57.1
REAR: 31x15.5-15 RC: 93
ratio: .6140 (13% diff!)
proposed change:
FRONT: 23x8.5-12 RC: 68.9
ratio: .7409 (0.4% diff)
Of course that means I need to find myself some front 12x8 rims with on a 6x4.5 lug pattern. I'm not too sold on this route yet. Steering effort is already a little high, and going to a taller wider tire isn't going to help any. I could go to a 6-12 tire on the front and keep the same F-R ratio, and I bet that would be easier to steer (and find a rim for). However, I don't want to be rutting up the yard too much.
11,323
REAR: 8-12 RC: 92.5
ratio: .7449
current tires:
proposed change:
Of course that means I need to find myself some front 12x8 rims with on a 6x6 lug pattern. I'm not too sold on this route yet. Steering effort is already a little high, and going to a taller wider tire isn't going to help any. I could go to a 6-12 tire on the front and keep the same F-R ratio, and I bet that would be easier to steer (and find a rim for). However, I don't want to be rutting up the yard too much.
I was going to suggest the 23x8.5-12 but I don't know if they will fit and clear things like loader, frame, steering linkage.
And as you too pointed out, bigger tires are hard to steer.
I've got 2 B7100HST's here and I'm working on changing one of them to hydraulic steering, I think it will be a nice add on.
iangoround
B7100HST w/ L1630
May 13, 2019
39
Rochester, NY
So here's a question. If I wanted to go that route, where can I find a 12x7 6 lug rim that fits?
I'm pretty sure the 23x8.5-12s would fit.
iangoround
B7100HST w/ L1630
May 13, 2019
39
Rochester, NY
Update: they don't fit.
I remembered that my cub cadet has 23x8.5-12s on the rear. The rims don't bolt up, but even getting it close it's obvious they won't clear the loader frame when turning.
Not sure if 6-12s would be any better.
11,323
If it's a factory loader then the 6-12's will fit and clear.
iangoround
B7100HST w/ L1630
May 13, 2019
39
Rochester, NY
Cost, mostly. My rears are still plenty good and changing rears is much more expensive than changing fronts.
zigoapex
b7100d
Oct 10, 2022
Scott twp
I have b7100d needs new tires on the front, i bought 20.5x8x10 turf (turf on back also) but they look to be bigger than what's on the tractor. am i going to mess up the 4wd? thanks.
Lencho
B7100hst
Jan 21, 2017
453
122
NM
Hi zigoapex,
what sizes do you have now front and back?
zigoapex
b7100d
Oct 10, 2022
Scott twp
Hi zigoapex,
29x1215 on the back and they are 20.5x8x10 on the front. I bought 20.5x8x10 but the rim centers are 4 inch and wont fit. They are going to return them. I’m going to use my old rims so i going to just order the tires.
JosephGozo
Kubota B7001 + an ever growing list of attachments (restored / homemade) :(
Nov 25, 2014
85
36
Malta
hi
sorry to bump in, given that the B7001 has 5-12 on the front and the B7100 has 6-12 on the front it means that there is a ratio change somewhere. Anyone can tell whether it is in the front axle/ its final drives or the gearbox?
thank you.
