Rhino TS10
BigG
Sep 14, 2018
1,953
774
West Central,FL
I saw this on TTWT and I was hoping someone on here might have or tried to use one. It is a 10ft bat wing mower that requires 25-50 pto hp, and one remote. It is a flexible mower which is what appealed to me, 90 degrees up and 22 down with 3 spindles.
Thank you, G
Bmyers
May 27, 2019
3,541
4,620
Southern Illinois
Just watched a video with TTWT using it on his JD2038. Told my wife that I could get that for my L3560.
I was wondering if anyone on here has used one also, guessing from the lack of response no one has.
10,181
Thank you, G
Too much of a HP requirement for your L2501. ;)
10,181
You would be right at the edge of the HP requirements, a heavy cut will have you crawling with that big of a mower. ;)
BigG
Sep 14, 2018
1,953
774
West Central,FL
I was working on a bid to mow the fields around a shopping center. I have a New Holland TL80 that I use a Rhino TW-96 with hydraulic offset. However the TW-96 does not follow curves very well and the areas around the shopping center have several ditches and ponds to mow i.e. slopes both up and down. That is why I was looking at the TS-10. It is large enough to mow the large flat areas and flexible enough to mow the ditches and pond banks without scalping the ground at every hump or bump. Or at least that is what I was trying to find out.
I do not think the 2501 would be heavy enough to pull the mower let alone get on a slope or hillside, beside the fact it is short on PTO power.
