anyone use lock n lube grease coupler, I bought the XL for some of the harder to reach fittings? I also bought the grease caps, any thoughts.
I ran into this. I have several fittings that LNL makes it impossible to grease. As nice as it is I'm not switching end every time I grease.It's OK, can be an issue if you have tight, hard to access fittings.
Ditto. I love both of these additions to my greasing chores.I've been using the L&L for a year on both my guns. Make greasing a breeze. For the occasional hard to reach fitting, I use a needle attachement.
I also use plastic L&L zerk fitting caps. They are yellow, and not only do they keep dust/dirt off the fittings, the bright color helps me see where all my fittings are so I don't forget any!
