Yellow break pedals
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Just curious as to why Kubota has yellow break pedals on early B series tractor? Pretty much every B series tractor I've seen weather it was a grey market or a U.S. model has yellow break pedals and I've always wondered why that is. Does anybody happen to know?
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
May be because it looks cool Eric:D on the other hand it may be to make them stand out from the rest of the tractor when you need to find them in a panic;):D didn't they paint the fill,drain and adjust bolt heads to make them easy to find?
300zx
1979 B7100D, 2009 ZG20, 1991 B2150, 1990 B6200
Dec 1, 2010
445
Forest, VA
Eric, I have had the same question, I just never got around to posting it. If it was to make them stand out, why didn't they do it on the other series tractors. Inquiring minds want to know.
If I ever paint the chassis, I have wondered if I am anal enough to keep them yellow!! Who ever repainted my son's B6100 repainted them yellow. It is the wrong yellow, but they are yellow.
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
Probably the same reason stop signs are red, It makes them stand out, Gets your attention quickly, Why they did not continue the practice is also a good question.
Ironically I think most operators once having determined the brake pedal location no longer need the color to help them locate the brake pedals, Just like the operator of a car or truck with a standard transmission does not need the gas/brake/clutch pedal highlited in a different color because once familiar with the location the need to look at the pedals is no longer needed, It is done from memory.
I kinda like the yellow pedals on my B5100E and if I ever got around to repainting it I would probably repaint them in yellow.
DickSnyder
L185DT, L1200 FEL, Rear blade
Jul 29, 2011
77
Mt. Hood Parkdale, Oregon
I have an early L185DT and it has yellow brake pedals as well. Maybe that was the only color they had left in the factory that they hadn't used yet!!!!! :D:D
Dick
aquaforce
L245DT FEL, JD450 Track loader, 5' scrape blade&mower, 5x10 trailer, Dump truck
Apr 22, 2009
757
Stockbridge, Ga. USA
My L175 used to have yellow pedals. The yellow was original but when I painted my tractor they turned BLUE.
Personally I liked the uniform color and the yellow just stuck out like a sore thumb. Keeping all the Kubota Blue uniform was my choice. :D:D
Before and after pics.
