B5200 Squealing
ChrisBob
B5200
Jul 3, 2019
Los Osos, CA
Hello -
I have a Kubota B5200 with the rototiller attachment. Everything works fine till the blades of the tiller are lowered to the ground and make contact. The blades will stop spinning and a squealing noise is made. Does this sound like the clutch slipping?
Thanks
10,694
Does the tractor also stop moving?
If yes then it also certainly the clutch
If no then it's something broken internally.
BX25D Rookie
2011 BX 25LB-R (dirt work, snow, and brush hogging) & 2013 BX 2370 (mowing lawn)
Mar 21, 2019
255
344
upstate, NY USA
Rototiller on the rear of your tractor?
3 point hitch mounted?
What type of PTO shaft are you using?
Shear bolt or slip clutch?
If you have a slip clutch PTO shaft, the slip clutch could be worn out
or improperly adjusted.
ChrisBob
B5200
Jul 3, 2019
Los Osos, CA
It is a rototiller on the rear with a slip clutch PTO shaft. I can try to post a video today (if I can figure out how to do it). I have never adjusted it in the over 10 years I have used it. If that is the problem, is it normal for the clutch to start slipping with no warning?
Thanks
ChrisBob
B5200
Jul 3, 2019
Los Osos, CA
Not sure why my replies didn't post, but I will try again.
Thanks for the help and quick responses.
- BX25D - The tractor is able to keep moving like normal
- Wolfman - It is a rear mounted tiller with a slip clutch. I have never adjusted this clutch in the over ten years I've had it. I will look more into that and maybe post a video if needed.
Thanks again
Chris
