Boom pole
4,685
I picked one up as an impulse buy at an auction paid like 50 bucks for it,, a tatter brand, I think TS handles them. it looked brand new. Well I used it today. I have some stuff down from storms and I really cant bull stuff around like I use to. So I put it on the BX and went over the hill,,, well dayum, :eek: it lifted trees up to the point where I could cut them standing up right almost. It took a little bit of figuring how to chain the trees to cut but I like it,,Yeah I know a bucket with a grapple would work better maybe on the next one ;)
2,970
I had one on my 53 Jubilee - worked great.
I welded a hook near the end, chain or choke the load and hook to welded hook.
Worked like a charm.
Great to reach over something and have a long arm.....still have to know your limitations!:D
raptorfan85
L2501, woodland mills wc46 chipper, 60" bolens finish mower, old cordwood saw
May 4, 2019
Richmond NH
I bought one from tractor supply years ago. Use it to drag logs out of the woods for firewood. Works great!
In Utopia
L175 FEL
Apr 21, 2013
652
180
Utopia,Tx/Pasadena,TX
Got mine from TSC about 10 years ago. The had it on clearance for $50.
Added a winch, and it's paid for itself many times over. It plus a hydraulic top link and winch have made getting downed trees to the burn pit.
6,021
I made one to haul a set of tandem discs using my A-C D-14. Easier than loading discs onto 6by8 flatbed, towing it with tractor, unloading ,hokking up, discing then sigh, doing same to get home..
Once I figured out 'tie-downs', road travel was easy and fast !
Smokeless
3901/Loader/Rear Blade/Box Blade/LP Mower/Pallet forks IH M,,Cub & sickle mower
Feb 5, 2018
237
9
Southern Illinois
Doesnt that make the front end allot lighter???
In Utopia
L175 FEL
Apr 21, 2013
652
180
I was popping too many wheelies on my hilly property with any implement I was using, so I had it just a little bit of front end weight to help out.
When I move with a load like this, I pull the hydraulic link all the way in and a three point all away up, kinda helps with the balance
baronetm
L3901HST w/FEL, 3rd fnct. BH77 BH, 5' Bushhog, 6' BBL, 42" Forks, WoodMaxx WM-8H
Apr 19, 2017
122
12
South Central VT.
I made my own boom pole to fit on a SSQA plate. It is made from sch. 80 - 2" x 10 foot pipe with a welded 1/2" x 2" lower flat bar and rebar reinforcing and 1-1/4" support pipe. It will lift rail road ties rated at 200-300 lbs. each with ease.
