Well I finally had time to register so I can post on the OTT site!
I just removed my U-joint cover when I split the tractor and had about a small cup of lube in it also. I thought it might be leaking from front seal but checked levels in front and it seemed ok. Also, I cleaned up the front yoke area and leaned the front end down and in over a week none has seeped out of the front end so it may be factory lube for the front U-joint. Manual says nothing about servicing it and there is not a zerk on it.
thanks for the great info on this site!
