L2000DT PTO operation
Jim67
L225DT
Apr 29, 2019
40
Kernersville, North Carolina
Last weekend I was able to get the new to me tractor out for some bush hogging. I never really paid much attention but noticed sometimes the PTO didnt seem to disengage. Push the cluth in, move PTO shaft to neutral and bush hog kept spinning. I thought it was just coasting but seemed a little faster than that. I dont really know if there is a sequence or am doing something wrong? Dont think it did it everytime. Maybe RPMs?
5,518
If your putting it in neutral it should be in neutral period.
You do know that the PTO is multi speed right, are you sure your not just going past neutral and into another PTO speed?
Jim67
L225DT
Apr 29, 2019
40
Yes I know it has multiple speeds. Im not sure if it did it with PTO in neutral. Now that I think about it, I may have just had the clutch pushed in. Would that keep the PTO turning? I know there is "live PTO" and not but not sure the difference.
5,518
It would depend on if you have a dual clutch set up or not.
If it's a dual clutch then the PTO clutch could be sticking, or out of adjustment.
shootem604
Apr 23, 2018
875
British Columbia
I think this model is typical of most of the smaller early L series, and the PTO should stop with the clutch in. It definitely should stop with the PTO speed selector in neutral.
1,091
But you need to realize that it will take a while for the bush hog to slow down to a stop. You should hear it change speed soon after pushing in the clutch but two minutes or more to a dead stop would be a reasonable guess for coasting to a stop.
Jim67
L225DT
Apr 29, 2019
40
Yea thanks all. I drove the tractor around the yard without anything attached and put the PTO in gear and watched it spin, then pushed the clutch in and was totally amazed at how long it coasted before it stopped. That was with nothing attached.
