I have found a couple of threads talking about whether or not to use a clutch when changing between ranges on a hydrostatic transmission. It seems, some say it is not necessary. Others have said it is necessary and cite the manual for their specific tractor. I recently bought a L2501 and have operated it a total of about 10 minutes at most. In that time, I shifted back and forth from Low to Medium range a time or two. I used the clutch because I was not sure if I needed to or not and had not read the manual yet since the tractor was just delivered. When I did look in the manual, it seems the manual does not indicate the clutch has to be used, but the manual is worded goofy IMO and I know it also seems to unnecessarily state to do things for the sake of safety.
So, I was just curious if it matters or not.
