Adding a hydraulic top link, what size hose?
DawgDr.
Savannah, GA
Hi folks, I am going to add a hydraulic top link to my Kubota M6060 and I am not sure what size hose 3/8, 1/2?, fittings, and quick couplers to get for my application? Dealer is no help and local agrisupply has no idea either. Spoke to another hydraulic top link dealer, but a 20 week wait is more than I can stand. Planning to use the inexpensive option from Agrisupply.
thanks for any help you have give.
SDT
multiple and various
Apr 15, 2018
3,084
926
SE, IN
Smallest possible.
You want the cylinder to operate slowly to maximize resolution.
SDT
russell.still.5
197
Lafayette, Alabama
Ken’s Bolt On Hooks has some restriction orifice fitting. Mine has 1/2” hoses and has the restriction orifices to make the top link move at a controllable speed.
edritchey
A bunch of cute little Kubotas
Jul 19, 2014
1,080
756
Wellsville, PA
I put the factory hydraulic top link on my son's M7060 it came with 1/2" lines so I would think 1/2" is what you want to go with.
DawgDr.
Savannah, GA
Thanks, just what I needed. I did not see where Kubota made a hydraulic TL, do you see an aftermarket brand name on your system by chance?
SidecarFlip
Banned
548
Smallest diameter lines and a restriction orfice fitting. You can make your own restriction washer from a penny or the head of a spent rifle cartridge (the flash hole in the case will provide the necessary restriction.
edritchey
Jul 19, 2014
1,080
756
Wellsville, PA
We ordered it through whole goods I'll try to see if I still have the part numbers. I think it came as a top and tilt kit but we only use the top link we fabricated the tilt cylinder on a rear blade to make it angle. The top cylinder didn't need any type of restriction to work correctly.:)
BAP
Dec 31, 2012
2,534
672
1/4” is plenty big enough. 1/2” is overkill and more expensive.
5,130
933
Smaller the better for the hose. The quick coupler can be any convenient size for any implement you might also want to connect hydraulically at a future time.
You are not trying to move very much fluid unlike a FEL
If it is still too fast so you cannot make fine adjustments, then add restrictor.
russell.still.5
197
Lafayette, Alabama
I tried the penny restriction and it didn’t work for me. It confirmed the penny to the same size as inside of the fitting.
edritchey
Jul 19, 2014
1,080
756
Wellsville, PA
This is the kit we ordered:
TOP-N-TILT KIT (M SERIES)
L8326
Top (Cylinder) and Tilt (Cylinder) Kit
54 lbs
FTG-05
Jul 21, 2013
241
87
TN
I couldn't find them on Ken's site. Gotta a link?
Thanks,
