We have a B2920. Have had starting problems for quite awhile. We have taken it to the dealer and they couldn't find the problem. We put on a relay on the starter which we thought might help. The problem has returned. Presently if you play (for minutes) with the forward/reverse pedal it will usually start. I have read numerous threads on this very subject (this seems to be a pervasive problem with numerous models of Kubotas). People in the threads thought the ignition switch to be the problem, relay replacement recommendations, battery terminal connection reminders, safety switch problems and maybe other things.
At this point, because the tractor will start by playing with the forward/reverse pedal I am thinking it may be a safety switch. I have looked under the area of the pedal and can't see anything. Can anyone tell me how to find the safety switch?
Thank you.
Thank you.
